Another Aluminium OX - Just started
Discussion in 'CNC Mills/Routers' started by sgspenceley, Dec 5, 2014.
  1. sgspenceley
    sgspenceley Veteran
    sgspenceley published a new build:
  2. sgspenceley
    sgspenceley Veteran
    I'm waiting for the openbuilds parts to arrive so thought I would share some images authored in SolidWorks. Building the 3D CAD model really helped me understand the OX design, so building the real thing should now be easier.
    I'm going to use a Bosch Colt router to start off with, so designed a holder which I will have water jet cut. I also designed a small mounting plate to attach to the extruded aluminium Z axis .
    #2 sgspenceley, Dec 20, 2014
    Nick W likes this.
  3. sgspenceley
    sgspenceley Veteran
    I originally 3D modeled & built the Nema 23 Lead/Acme Actuator thinking this was required for the OX build.
    As part of this process I decided I liked the stability of the extra motor post so I designed my own version of the top & bottom mounting plate.
    Hytech2k, GrayUK and Jestah like this.
  4. GrayUK
    Really nice drawings my Friend
    Gray
    sgspenceley likes this.
  5. sgspenceley
    sgspenceley Veteran
    Thank you Gray, it was fun modeling in SolidWorks, it really helped me understand what I'm building. This site is great because it has lots of threads, put pulling all the files together took a little research. Also having a full parametric CAD model allow me to do lots of "what if" design scenarios, before I start cutting the aluminium profiles.
    A very special thank you to Mark Beers for many of the SolidWorks parts files. I used feature recognition to convert a number of files into native SolidWorks 2014 parts. When parts were not found I re-authored the missing files.
    #5 sgspenceley, Dec 21, 2014
    TMG likes this.
  6. sgspenceley
    sgspenceley Veteran
    I have now attached my work in progress SolidWorks assembly. Enjoy, but use with care...
    The two side plates have a distance set between them, if you adjust the distance all the geometry will update to the new width.
  7. webitman
    webitman New
    Exellent CAD drawings, this will be a great build to follow and I can't wait to see the final outcome, as this will certainly give me a lot more insperation to start mine.
    Paul
  8. sgspenceley
    sgspenceley Veteran
    Thank you Paul... I have the main plates cut now in aluminium and the open builds parts "should" arrive in a few days...
    I'm going to carefully document the build so it's easy for other newbie's to follow.
    #8 sgspenceley, Dec 23, 2014
    GrayUK likes this.
  9. Giancarlo Dalla Francesca
    A really nice work. Can You publish files in STEP format ?
  10. sgspenceley
    sgspenceley Veteran
    Hi giancario, yes no problem, the full assembly is now attached in step format.
    #10 sgspenceley, Dec 23, 2014
  11. sgspenceley
    sgspenceley Veteran
    I have now posted the complete assembly. Note I'm in the process of building from and evolving the design, so your free to use but comes with no warranty.
    Take time to thank Mark Beers for many of the original part files.
  12. sgspenceley
    sgspenceley Veteran
    A little more work on the z-axis.
  13. sgspenceley
    sgspenceley Veteran
    Openbuild parts arrived yesterday, all expertly packed and wonderful quality.
    My aluminium plates were waterjet cut locally, they required just a very small hole reaming to provide enough clearance for bolts & eccentrics. I'm very pleased with the quality of the plates.
    CNC-MachineAluminiumCrossGantry2.JPG CNC-MachineAluminiumEccentric.JPG CNC-MachineAluminiumSidePlates.JPG CNC-MachineAluminiumCrossGantry.JPG CNC-MachineAluminiumCrossGantry3.JPG
    Mark Carew, GrayUK and Robert Hummel like this.
  14. DarkAlchemist
    DarkAlchemist Well-Known
    Very nice indeed and I am flabbergasted at the quality you grabbed out of Solidworks on those first pics. HOW?!?
  15. sgspenceley
    sgspenceley Veteran
    Thank you DarkAlchemist. Nice rendering is very, very easy using the photoview rendering option built into SolidWorks.
  16. DarkAlchemist
    I figured that is what you used but I hardly hear of that anymore since the days of SW 2009/2010 days.
  17. Dave Lowry
    Nice build. I will be watching this from a SW enthusiast point of view and a future CNC builder point of view too. You have done a lot of work. Very nice. Did you ever consider the Shapeoko 3 that is in the works? I am tossing back and forth between ordering a Shapeoko 3 or building an OX. The $1000 dollar with router price tag is appealing for the Shapeoko 3, but the size of the OX keeps calling to me! Do you have a price estimate that you expect to be coming in at?
  18. Serge E.
    Serge E. Journeyman
    Check out the OXcalculator to get an estimate of a 'typical' OX build. Give it as little as the X, Y and Z dimensions of your OX build and it will generate a BoM and cost. Default item costs are mostly from OBPS, but you can drop in your own. A few updates are in works ...
  19. DarkAlchemist
    I don't care much for Shapeoko 1/2 and while 3 is a lot better it still is just too much for too little imo. It is getting there though so I have hopes S4 will be sturdy enough for my needs at the same cost as the S3 INCLUDING the spindle which has always been a toy version with the Shapeoko. If the Spindle is not at least 800 watts it can just stay at home imo.
  20. sgspenceley
    sgspenceley Veteran
    Thank you for your kind words Dave. The Shapeoko products look good, but I like the concept of knowing exactly what I'm buying and building. Plus the personal satisfaction of doing the build is great!
    I have ordered Grecko 540 kit, with 4 nema 23 which has pushed the price higher than I originally planned but hoping the finished solution will be worth the cost.
    The parts from openbuilds are excellent quality, expertly packed and arrive quickly.
  21. DarkAlchemist
    Exactly, the part about knowing what is in something matters a whole bunch but the part about designing something then seeing it work is priceless. The only thing I can think of that tops that is when someone, or a lot of someones, end up building your design. I can't think of anything that thrills me more than designing something and knowing at least someone besides myself was able to use it.
  22. snokid
    snokid Journeyman
    there is an ox in that price range as a kit also.
    http://www.spark-concepts.com/zeus-cnc-router-kit/
    the owner has pulled to kits till he get's caught up, but for the money it's a great kit....
    Bob
  23. Dave Lowry
    Thanks Bob and all else who answered. Bob this is exactly what I would be interested in. Something around $1000, that would not take a year to build. I just want to get a working router as soon as possible without breaking my bank. So aa 'everything you need' kit would suit me just fine. I get nervous when I see people who post their 'hello world' video and describe their year long journey bringing everything together. Is this what it typically takes someone who goes down the OX path? I ran that calculator, great work by the way, whomever did that, and I was seeing $1700. I am not familiar with all the components so I do not know if the one I downloaded was a typical build or not.
    I just emailed the Spark Concepts guy for more info. Thanks for the tip.
  24. sgspenceley
    sgspenceley Veteran
    The main frame now assembled. The X axis is a "little" too tight even when the eccentrics are backed off totally. No idea why because the extreme wheels fit the groove perfectly.
    Robert Hummel and Area51cncparts like this.
  25. DarkAlchemist
    I can only speak about a CNC 3d printer not a CNC router but the concept would be similar for this purpose.
    For a 3d printer if you buy an all in one kit they seem to go together over a weekend or a 6 hour no break sprint. For a self sourced 3d printer with only the wiki to go by it took me 16-18 hours non stop and another year to finally get it all dialed in (long story).
    So, I'd imagine if you buy a kit for a CNC Router you will end up paying more (10%-30%) BUT you should have a point of contact if anything is missing or isn't working properly. If the person you buy a kit from is not there for an after the sale session, if needed, they should be shunned from the open source community.
    Now, what I didn't see in that kit was a mention of a spindle and let me tell you they run some bucks. The controller (don't touch the Chinese craptastic controllers), Spindle (Chinese spindles seem to be okay for the most part) and a water cooler (air is alright but I value my hearing and 50-100 dollars more for that is worth it to me) can run 600 (expect so-so at this price) to 1200 (expect prosumer quality) to 2 grand (very good quality but way overkill for what we build).
    So, I have found that whatever the machine runs double it for a nice spindle setup. Too rich for my blood still but ymmv.
  26. Dave Lowry
    I will be cutting wood and plastics, rarely metals. My plan was to start with a strong wood router. Would I still need cooling?
  27. DarkAlchemist
    Well, cool
    Well, cooling is always needed but some spindles come with air turbines on the top of them and others have holes where the water+coolant connections go. Think of it like active cooling versus passive cooling in a PC but there is another reason I want it (I will be doing soft metals mostly myself) and that is the water cooling one you will mainly hear the bit whereas the turbine cooling is more akin to the ancient days of the 486 and those 60mm 8k rpm demon fans. Try being a PC tech and having to work on those darn things all day, lol.
    So, you can always go the air route if you wish and it will save you a C note approximately (50-100 dollars) I just have never liked air cooled spindles (besides the wind blowing from the spindle blowing the chips all over the place).
  28. snokid
    snokid Journeyman
  29. DarkAlchemist
    Nice to know but lets be real a HF router does NOT a spindle make. Two entirely different beasts with the winner being the spindle in every aspect. One of the biggest differences is that a spindle can go for hours and hours every single day whereas that router (or a palm router, Dremel, etc...) is not made for continuous duty like that. Oh, and the spindle, even an air turbine cooled one, is 10 million times quieter too.
  30. Rick 2.0
    The HF router is not entirely bad. It should at least last long enough to cut a mount for something a little more serious.;)
