A fully 3D-printable rotating stand for filament spools, designed to be easily made without the need for fasteners such as screws, nuts, shafts, glue, etc. Every single component in this spool holder comes right from your 3D printer's filament.
The spool holder's spindle is shaped to fit the vast majority of commonly used filament spools with shaft holes ranging from 16 mm to 62 mm in diameter. It is also compatible with spool-less filament coils.
The spindle which holds the spool's weight rotates on its own roller wheels, which makes it turn effortlessly.
The spool holder included an arm for filament guide tubes of both common sizes 1.75 mm and 3.0 mm. The arm also contains a pocket for inserting a piece of sponge which acts a a filament filter - thus keeping the filament clean and lubricated.
FEATURES
- Easy to 3D print
- Needs no glue or fasteners
- All parts can be 3D-printed
- Fits almost any filament spool size
- Has built-in filament filter!
- Can also hold spool-less filament coils
Next time you need a new filament spool holder, just 3D-print one!
By:
- Creative-Tools
- Google Plus
- Youtube
VIDEO
Universal stand-alone filament spool holder (Fully 3D-printable)
Build in 'Everything Else' published by CreativeTools, Dec 14, 2014.
A practical rotating and stand-alone spool holder which fits any filament extrusion 3D-printer. Several base files provided which make it fit different extruded aluminium profiles.
Domenic Aluise, JustinTime and Mark Carew like this. -
Build Author CreativeTools, Find all builds by CreativeTools
To provide a fully-3D-printable filament spool stand for 3D-printer operators. -
- File size:
- 26.8 KB
- 1,117
- File size:
- 17.6 KB
- 1,226
- File size:
- 22.3 KB
- 1,245
- File size:
- 21.3 KB
- 1,178
- File size:
- 25.9 KB
- 1,201
- File size:
- 23.4 KB
- 1,147
- File size:
- 28.5 KB
- 1,226
- File size:
- 32.2 KB
- 1,232
- File size:
- 32.9 KB
- 1,250
- File size:
- 29.7 KB
- 1,104
- File size:
- 31.5 KB
- 1,339
- File size:
- 20.4 KB
- 1,146
- File size:
- 29.5 KB
- 1,075
- File size:
- 20.2 KB
- 1,303
