      15 votes
      ! Complete Sphinx Kit !
      I am often asked, if I offer or can recommend a complete Sphinx cnc kit? I do not offer / sell or make any money from my sphinx design. However I am happy to announce you can now pickup your own complete Sphinx CNC kit directly from the crew here at OpenBuilds !
      Complete Openbuilds Sphinx CNC Kit
      "Here"
      I do know about the numerous kits online (ebay / aliexpress / websites /ect. ). I do not know the quality or completeness of these kits ! Please research who is offering them as neither openbuilds nor myself can offer support for those kits. With the Openbuilds kit linked above you get quality and peace of mind knowing they asked my ( the designer ) permission. They also provide the fair-share giveback program to help builders grow and learn and most important you get quality customer service you can rely on through out your build and beyond.
      ! Complete Plate Set !
      I get asked this often, what plate set to buy when building a Sphinx cnc? I see a number of sets have popped up for sale online (even on aliexpress) I do not know the quality or fitment of each set being offered online please research who is offering them ! The Two plate sets I can recommend are from Openbuilds Directly and Chris ( blue-ox ) Both are quality sets I have personally used.
      Openbuilds Sphinx plate set
      "Here"
      Chris's plate set
      "Here"
      This is the C-beam Sphinx a strong desktop cnc router that will enable you to make larger aluminium plates without taking up to much room. Simple, strong and opensource !
      C-beam Sphinx? The bulk of this machine and every axis is built upon the strong openbuilds C-beam linear rail and much as the Sphinx of myth inherits attributes from many to create one. So do I build from ideas shared with the community.
      From Mark Carew with his Ox and Plate Maker, Robert Hummel and his Stinger-V to sm3d and their R7. Each has inspired me to design build and explore this world of cnc that has lead to the design you are now reviewing.
      Goals with this build:
      - Many openbuilds parts
      - Ease of construction
      - Full documentation
      - Flexible growth
      - Strong
      I would like to think I have reached those goals!
      The C-beam Sphinx was designed in Sketchup and you will find a full cad model in the attached zip under the "Files and Drawings" tab for this build. Along with Sketchup, I have used Fusion 360 to design the new plates of course the .f3d files are also included.
      I encourage you to build modify and share your C-beam Sphinx build. Everything you need to get started is within the included zip file.
      2018.Feb.4 Added zip folder named "Cutlists" under the files tab that shows the extrusion lengths required for larger builds. when building larger then the original build outlines you will also need longer lead screws! A good rule of thumb is axis length plus 40mm.
        File size:
        66.9 KB
        10,217
        File size:
        910 KB
        9,827
        File size:
        915.5 KB
        9,808
        File size:
        140.5 KB
        9,815
        File size:
        924.1 KB
        9,756
        File size:
        899.9 KB
        9,834
        File size:
        854.9 KB
        9,980
        File size:
        910 KB
        9,562
        File size:
        909.5 KB
        9,880
        File size:
        857.5 KB
        9,609
        File size:
        296.3 KB
        10,743
        File size:
        830.9 KB
        10,221
        File size:
        904.9 KB
        9,753
        File size:
        995.1 KB
        9,988
        File size:
        991.1 KB
        9,834
        File size:
        973.9 KB
        9,731
        File size:
        854.3 KB
        9,892
        File size:
        973.3 KB
        9,954
        File size:
        966.2 KB
        9,795
        File size:
        954.3 KB
        9,950
        File size:
        943.6 KB
        9,663
        File size:
        803.1 KB
        9,510
        File size:
        983.9 KB
        9,781
        File size:
        875.4 KB
        9,737
        File size:
        792.5 KB
        9,306
        File size:
        916.8 KB
        9,597
        File size:
        862.1 KB
        9,611
        File size:
        713.7 KB
        9,659
        File size:
        861.6 KB
        9,557
        File size:
        922.9 KB
        9,619
        File size:
        878.7 KB
        9,576
        File size:
        940.9 KB
        9,600
        File size:
        976.1 KB
        9,663
        File size:
        933.2 KB
        9,531
        File size:
        983 KB
        9,542
        File size:
        884.4 KB
        9,226
        File size:
        953.3 KB
        9,469
        File size:
        943 KB
        9,507
        File size:
        956.5 KB
        9,435
        File size:
        932.3 KB
        9,407
        File size:
        887.7 KB
        9,426
        File size:
        925.5 KB
        9,444
        File size:
        898.8 KB
        9,603
        File size:
        963.9 KB
        9,454
        File size:
        829.5 KB
        9,524
        File size:
        977.2 KB
        10,288
        File size:
        887.6 KB
        9,538
        File size:
        916.1 KB
        9,601
        File size:
        933.9 KB
        9,382
        File size:
        908.7 KB
        9,428
        File size:
        921.2 KB
        9,488
        File size:
        942.5 KB
        9,468
        File size:
        935.5 KB
        9,349
        File size:
        942.2 KB
        9,208
        File size:
        848.5 KB
        9,177
        File size:
        901.8 KB
        10,112
        File size:
        914.6 KB
        9,105
        Want a larger cnc? I have included a complete sketchup file for a larger machine adjust your b.o.m to fit!
    1. Build Author , Find all builds by Kyo
    To get a few more inches of work space out of a cnc the same size as my c-beam machine plate maker. I also wanted to go fixed bed but continue to use the awesome c-beam.
    Both Mark Carew and Robert Hummel have inspired me with all thier builds. The C-beam Machine Plate Maker , Stinger-V and the R7 Have inspired this design.
    1 bill of material http://www.openbuilds.com/attachments/c-beam-cnc-b-o-m_li... Link Updated Links
    1 cut List Link provided in zip file.
    0 Link
